Hi all members,
I am trying to get the coordinates of Revit element from Survey point. For example, coordinates of piles based on survey point.
As a first step, I used Get Location node for the selected elements, and it gives the coordinates from the internal origin.
Then I get the location of Survey point as well.
The question is
How are we going to cater the orientation of the project to get the real-world coordinates of the Revit objects?
I do really appreciate all the suggestions.
Hi Ethan, welcome to the forum,
Please take the time to read the FAQ if you haven’t already
There are plenty of discussions regarding this in the forum - only a quick search away
Crumple has a node Coordinates.SP which reports eastings and northings
Does this take into consideration the angle of the PBP against the SP?
Here is an article that I wrote. I hope it helps!
Here’s three ways to achieve a location point readout relative to the survey
Simplest is using GeniusLoci node
Convert from InternalOrigin CoordinateSystem
Next is a python node
transform = doc.ActiveProjectLocation.GetTotalTransform()
def transform_point(p):
# Unit conversion done with ToXyz and ToPoint methods
return transform.Inverse.OfPoint(p.ToXyz()).ToPoint()
# Provide a list of points
points = IN[0] if isinstance(IN[0], list) else [IN[0]]
OUT = map(transform_point, points)
Finally, use OOTB and Crumple Coordinates.SP to create the transform as a CoordinateSystem and apply to the geometry
