Hey guys, this is a bit of a generic question. Hope you can help me out a bit
Is it possible to collect the area of a specific material in a family? For example, i want to extract the area of glass in a window, without having to make a parameter, that calculates it. Point me in a direction
I did just find that Thx tough… Problem is that it takes of material total surface, sides aswell. Guess i have to find another way around this. Do you no if its possible to get the solid, a material is assigned to?
I quick way to do this is also with the Element.Materials Node and the Element.Geometry node.
If i am correct the Element.Geometry node will give you all the solids in the Family. Measure their Volume and compare it to the Materials Volume from the Element.Materials. Their should be a solid with the same volume as the Glass Volume. Filter that one and you have your solid.
