Family's Materials Name Sort Group
Hi everyone,
I am wondering something. I created basic box family. And then I did paint some surfaces with paint tool in Revit.
I want to ask this. Can I grouped paint area and non paint area ? or How to group material name this areas ?
Thank you so much.
@DynaGirlBIM you can get that within the family through parameters and formulas, then schedule your families in Revit project
If you’re comfortable with Python you might do something like that:
I’m not aware of an existing node that could give you the different materials applied to faces of an element.
Hi tradeli, you are right. but it is very complexly. Maybe I think there must be an easier way?
So, Thanks for advice. [quote=“Elie.Trad, post:2, topic:75130, full:true”]
[/quote]
:ok_hand:
Hi @viktor_kuzev ,
Well done. This is wonderful.
Could you please, Can you add it as text please? :+1: :pray:
Hi again @viktor_kuzev ,
I took a error message. Where is the problem ? I did not find it.
I had to rewrite it since I didn’t save it yesterday.
And I also tried it in Revit 2022
import sys
clr.AddReference('RevitAPI')
opt = Options()
materials = []
faces = []
geometry = UnwrapElement(IN[0]).get_Geometry(opt)
for obj in geometry:
	instanceGeometry = obj.GetInstanceGeometry()
	for solid in instanceGeometry:
		if solid.Volume>0:
			for face in solid.Faces:
				materials.append(doc.GetElement(face.MaterialElementId))
				faces.append(face.Convert()[0])
# Place your code below this line
OUT = faces, materials
This is the exact code I used.
And Dynamo version.
I suspect the problem at your side is with the Python installation, but I don’t really know. Try this code, try restarting the program and if it doesn’t work we’d need to summon the experts
Thank you so much @viktor_kuzev ,
Now, this script runned. No problem for me. But I do not undertand. I write same this too. It did not work. But it is runnign interesting :slight_smile:
Thanks for sharing this solution :pray:
Try running the two through a tool that checks for differences between two documents.
But I suspect something else went wrong the first time with the way Dynamo executed the code itself.
