I try to create line using coordinate but it show these error AttributeError: 'type' object has no attribute 'CreateBound'
These is code I used to get coordinate
# Import Common Language Runtime
# Import Revit Services
clr.AddReference('RevitAPI')
import System
#get the document
#Function
def line(number1, number2, number3, number4, number5, number6, number7):
    x1 = number1
    y1 = number2
    z1 = number3
    x2 = number4
    y2 = number5
    z2 = number6
    nx1 = number1 + number7
    count = 0
    while (count < 2):
	    pt1 = XYZ(x1, y1, z1)
	    pt2 = XYZ(x2, y2, z2)
	    pt3 = XYZ(nx1, y1, z1)
	    pt4 = XYZ(nx1, y2, z2)
	    y1 = y1 + number7
	    y2 = y2 + number7
	    count = count + 1
	    mylist.append(pt1)
	    mylist.append(pt2)
	    mylist.append(pt3)
	    mylist.append(pt4)
num1 = IN[0]
num2 = IN[1]
num3 = IN[2]
num4 = IN[3]
num5 = IN[4]
num6 = IN[5]
num7 = IN[6]
mylist = []
result = line(num1, num2, num3, num4, num5, num6, num7)
OUT = mylist
Which I successfully build loop creation of pt but when I try to add create line into these loop function to looping create line but it shown error AttributeError: ‘type’ object has no attribute ‘CreateBound’. However, I have been searching for command used to create line by coordinate even RevitAPIdoc give me these scripts
Line1 = Line.CreateBound(pt1, pt2);
So I try to insert these line of code into my while loop as follow
import System
#get the document
#Function
    x1 = number1
    y1 = number2
    z1 = number3
    x2 = number4
    y2 = number5
    z2 = number6
    count = 0
    while (count < 2):
                line1 = Line.CreateBound(pt1, pt2)
                line2 = Line.CreateBound(pt3, pt4)
	    y1 = y1 + number7
	    y2 = y2 + number7
	    count = count + 1
	    mylist.append(pt1)
	    mylist.append(pt2)
	    mylist.append(pt3)
	    mylist.append(pt4)
num1 = IN[0]
num2 = IN[1]
num3 = IN[2]
num4 = IN[3]
num5 = IN[4]
num6 = IN[5]
num7 = IN[6]
mylist = []
OUT = mylist
My target is to repeat create 2 line for each time while loop looping but it keep notice me of these error AttributeError: ‘type’ object has no attribute ‘CreateBound’. Did I forgot to import some function?
Hello @somphon
you have a conflict between 2 namespaces (Revit API , and Dynamo Proto API)
remove this if you don’t use it
or use an alias
Line1 = DB.Line.CreateBound(pt1, pt2)
Thank you for reply I really appreciate and I have a bit curiosity because I tried ur suggestion and it successfully run without any error but instead I didnt saw graphical line drawing on my dynamo screen these is my code after I made an adjustment about namespace conflict.
import System
#get the document
#Function
    x1 = number1
    y1 = number2
    z1 = number3
    x2 = number4
    y2 = number5
    z2 = number6
    count = 0
    while (count < 2):
	    line1 = DB.Line.CreateBound(pt1, pt2)
	    line2 = DB.Line.CreateBound(pt3, pt4)
	    y1 = y1 + number7
	    y2 = y2 + number7
	    count = count + 1
num1 = IN[0]
num2 = IN[1]
num3 = IN[2]
num4 = IN[3]
num5 = IN[4]
num6 = IN[5]
num7 = IN[6]
mylist = []
OUT = line
It turn out that result said IronPython.Runtime.Pythonfunction. I have no idea what is mean. Im actually plan is to used this curve to later create rebar by curve.
@somphon
a few comments
  • your function return null, you need to use the “return” keyword to return a result (instead of using global variable)
  • Try to avoid not reassigning multiple variable names for the same reference
  • To convert Revit geometry to Dynamo geometry, you will find very useful information here https://github.com/DynamoDS/Dynamo/wiki/Python-0.6.3-to-0.7.x-Migration
an example with your code
import sys
import System
#get the document
#Function
def line(x1, y1, z1, x2, y2, z2, increment):
	outLine = []
	nx1 = x1 + increment
	count = 0
	while (count < 2):
		outLine.append(line1)
		outLine.append(line2)
		y1 = y1 + increment
		y2 = y2 + increment
		count = count + 1
	return outLine
NumX1 = IN[0]
NumY1 = IN[1]
NumZ1 = IN[2]
NumX2 = IN[3]
NumY2 = IN[4]
NumZ2 = IN[5]
increment = IN[6]
result = line(NumX1, NumY1, NumZ1, NumX2, NumY2, NumZ2, increment)
OUT = [x.ToProtoType() for x in result]
