Get Worksets from Excel
Hi @Konrad_K_Sobon , @c.poupin , @Jonathan.Olesen
I have the same problem with version “2021.25.3”, I use an Excel version 2013 and Excel for Microsoft 365 in French language. Any thoughts?
Excel files:
“Microsoft Excel 2013 MSO 64 bits”
ou
“Microsoft Excel pour Microsoft 365 MSO 64 bit”
Dynamo 2.3.1
Revit 2020
Dynamo 2.6.1
Revit 2021
# Copyright(c) 2016, David Mans, Konrad Sobon
# @arch_laboratory, http://archi-lab.net, http://neoarchaic.net
import sys
import System
from System import Array
clr.AddReferenceByName('Microsoft.Office.Interop.Excel, Version=11.0.0.0, Culture=neutral, PublicKeyToken=71e9bce111e9429c')
from Microsoft.Office.Interop import Excel
System.Threading.Thread.CurrentThread.CurrentCulture = System.Globalization.CultureInfo("en-US")
from System.Runtime.InteropServices import Marshal
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
from os import path
assemblies = System.AppDomain.CurrentDomain.GetAssemblies()
path1 = [a.Location for a in assemblies if 'bumblebee,' in a.FullName][0]
path2 = System.IO.Path.GetDirectoryName(path1).rsplit('\\',1)[0]
bb_path = '%s\\extra\\' %path2
sys.path.append(bb_path)
import bumblebee as bb
#The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
filePath = IN[0]
runMe = IN[1]
if filePath != None:
	if filePath.GetType() == System.IO.FileInfo:
		filePath = filePath.FullName
def SetUp(xlApp):
	# supress updates and warning pop ups
	xlApp.Visible = False
	xlApp.DisplayAlerts = False
	xlApp.ScreenUpdating = False
	return xlApp
def ExitExcel(xlApp, wb):
	# clean up before exiting excel, if any COM object remains
	# unreleased then excel crashes on open following time
	def CleanUp(_list):
		if isinstance(_list, list):
			for i in _list:
				Marshal.ReleaseComObject(i)
			Marshal.ReleaseComObject(_list)
		return None
	xlApp.ActiveWorkbook.Close(False)
	xlApp.ScreenUpdating = True
	CleanUp([wb,xlApp])
	return None
try:
	errorReport = None
	if runMe:
		message = None
		try:
			dataOut = []
			xlApp = SetUp(Excel.ApplicationClass())
			if path.isfile(unicode(filePath)):
				xlApp.Workbooks.open(unicode(filePath))
				wb = xlApp.ActiveWorkbook
				for i in range(0, xlApp.Sheets.Count, 1):
					dataOut.append(xlApp.Sheets(i+1).Name)
		except:
			xlApp.Quit()
			Marshal.ReleaseComObject(xlApp)
			pass
		errorReport = "Set RunMe to True."
except:
		# if error accurs anywhere in the process catch it
		import traceback
		errorReport = traceback.format_exc()
#Assign your output to the OUT variable
if errorReport == None:
	OUT = dataOut
	OUT = errorReport
Thanks in advanvce Cheers
Get Worksheet Names_D230_R20.dyn (17.7 KB)
Get Worksheet Names_D261_R21.dyn (19.3 KB)
test_Classeur1.xlsx (8.5 KB)
test_Classeur2.xlsx (8.5 KB)
Try running the office repair tool, which you can find on-line via a few google searches.
Also a quick reminder that office 2013 reaches the end of it’s supported lifecycle in 11 months; an upgrade now may save you the headache of unsupported software later and resolve that issue (or it could make it worse - partner with your MSFT expert to confirm).
Hi, @paris
obviously, ‘your Dynamo’ cannot find an assembly because it is not loaded. (bumblebee.dll)
Check the presence of the DLL and if they are not locked
Hi @c.poupin , thank you very much, you’re right, it works as expected with a package loaded.
Is there any way to get the Worksheet Names of excels files from path with a python node (standalone, without .DLL) ? . Thanks in advance for your help. Have a good day. Cheers
Check out the Sparrow package which has a node in it that can read worksheets and is in Python. It uses the microsoft interop utilities which are available as long as you have Excel installed I think.
here a solution
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import net library
from System.Collections.Generic import List, IList, Dictionary
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
clr.AddReferenceByName('Microsoft.Office.Interop.Excel, Version=11.0.0.0, Culture=neutral, PublicKeyToken=71e9bce111e9429c' )
xlDirecDown = System.Enum.Parse(Excel.XlDirection, "xlDown")
xlDirecRight = System.Enum.Parse(Excel.XlDirection, "xlToRight")
xlDirecUp = System.Enum.Parse(Excel.XlDirection, "xlUp")
xlDirecLeft = System.Enum.Parse(Excel.XlDirection, "xlToLeft")
class ExcelUtils():
	@staticmethod
	def GetDatas(filepath):
		ex = Excel.ApplicationClass()
		ex.Visible = False
		lst_xls = []
		workbook = ex.Workbooks.Open(filepath)
		ws = workbook.Worksheets[1]
		##get number of Rows not empty ##
		rowCountF = max(ws.Range(i).End(xlDirecUp).Row for i in ["A65536", "B65536", "C65536", "D65536", "E65536", "F65536", "G65536", "H65536"])
		##get number of Coloun not empty ##
		colCountF = max(ws.Range(i).End(xlDirecLeft).Column for i in ["ZZ1", "ZZ2", "ZZ3", "ZZ4", "ZZ5", "ZZ6", "ZZ7", "ZZ8", "ZZ9"])
		if rowCountF == colCountF == 1:
			fullrange = ws.Cells(1, 1)
			fullvalue = [fullrange.Value2]
			fullrange = ws.Range[ws.Cells(1, 1), ws.Cells(rowCountF, colCountF)]
			fullvalue = list(fullrange.Value2)
		print(fullvalue)
		#split list into sublist with number of colum
		n = colCountF
		datas = list(fullvalue [i:i+n] for i in range(0, len(fullvalue ), n))
		ex.Workbooks.Close()
		ex.Quit()
		if workbook is not None:
			Marshal.ReleaseComObject(workbook)
		if ex is not None:
			Marshal.ReleaseComObject(ex)
		workbook = None
		ex = None
		return datas
toList = lambda x : x if hasattr(x, '__iter__') and not  isinstance(x, (str, System.String)) else [x]
lstPath = toList(IN[0])
out = []
for xlspath in lstPath:
	lst_xls_Wkset_Name = ExcelUtils.GetDatas(xlspath)
	# flat
	lst_xls_Wkset_Name = sum(lst_xls_Wkset_Name, [])
	lstWkset = FilteredWorksetCollector(doc).OfKind(WorksetKind.UserWorkset).ToWorksets().FindAll(lambda x : x.Name in lst_xls_Wkset_Name)
	lstWkset = sorted(lstWkset, key = lambda x : lst_xls_Wkset_Name.index(x.Name))
	out.append([lst_xls_Wkset_Name, lstWkset])
OUT = out
Hi @c.poupin thank you very much for your great code, but
with “Microsoft Excel 2013 MSO 64 bits” (from Microsoft Office Standard 2013) I have the output values trasposed:
and if I use Excel “Microsoft 365 Apps for entreprise” I have this issue:
Thanks in advance.
Cheers
Thank you very much @GavinNicholls it works as expected (without DLL) !
hi, thanks for the report, I fix the code here
Note
unfortunately, I can’t test with Microsoft 365 currently
Thank you @c.poupin , I still have some issue with the python node, I’ll investigate a bit more the causes…maybe it’s a bug if I use Excel 2013… Cheers
test_excel.xlsx (8.7 KB)
