I am struggling to add a filter for selected line styles in active view only, the graph collects all selected line type in the project, is there a way to add a current view or select a view. Greatly appreciate your help:
Assuming you mean Detail Lines, you can get the OwnerViewId and match it with the active view. There are also custom packages with nodes for getting elements in a view or checking visibility based on view.
Not just Detail Lines, it could be Model line too. I can change the script to filter elements in active view, but then i can get name of those specific lines. I hit a wall when it comes filtering them out.
Since model lines are not view specific, you would have to use a method that checks based on visibility. This can still be a little tricky as elements can be “hidden” in a view in ways that they’re still technically “visible”. Getting them based on view like the node @christian.stan suggested is still your best bet.
You are asking for Element.Id on a text output (plug into an element)
cordially
christian.stan
This works @christian.stan Thanks, just a quick question though, is there a way to group the same types together instead of showing individual results:
the main thing is to try and understand (the connection of incoming and outgoing at each node, what do I have, what do I want to send, how to transform it, these are the questions that I ask myself posed at each stage),
remain humble,
everything has been through the beginning except the designers (there must be many exceptions)
Cordially
christian.stan
