I am trying to calculated totals of selected elements length in active view, but for some reason its counting in entire project:
Sorry was away from my computer. Weird. It’s thinking the Select is an input and not a function. You can remove the “lns =” in front of it as shown in line 3 in the image. I was doing some other testing and forgot to remove it before posting. If that doesn’t work, try adding “Revit.” to the front as shown in line 4 in the image. Lines 3 and 4 are doing the same thing, so you won’t need both.
If you can’t get the code block to work correctly, you can just use OOTB node as shown.
This is great Samuel! Let me try to select this way. Thank you for your help.
