Hi
I’m trying to work out the best way to get the time zone from a file. There is the calculateTimeZone method which relies on sun settings. But the SunSettings.Current node sometime fails becuase presumably the user is in a view with no sun settings (not sure if this is possible but it does fail).
#The inputs to this node will be stored as a list in the IN variable.
sunSettings = IN[0]
timeZone = sunSettings.InternalElement.TimeZone
DST = sunSettings.InternalElement.UsesDST
#Assign your output to the OUT variable
OUT = timeZone, DST
The other way appears to be the TimeZone Property which is after a city. Is this a more robust way of obtaining the time zone and if so, what is the best way to get it?
# Import RevitAPI
clr.AddReference('RevitAPI')
# Import ToProtoType, ToRevitType geometry conversion extension methods
# Import python library
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
import os
import shutil
import math
import collections
# Import math library
from math import *
#Import Data and Time
from datetime import datetime
now = datetime.now()
#Import System Library
import System
from System.IO import Directory, Path
app = uiapp.Application
site = doc.SiteLocation
angleRatio = math.pi / 180;
prompt = "Current project's Site location information:"
prompt += "\n\t" + "Latitude: " + str(site.Latitude / angleRatio) + "°"
prompt += "\n\t" + "Longitude: " + str(site.Longitude / angleRatio) + "°"
prompt += "\n\t" + "TimeZone: " + "(UTC%s)" % (str(site.TimeZone));
OUT = prompt
is this what you are looking for?
thanks. I end up simplifying as follows:
site = doc.SiteLocation.TimeZone
OUT = site
