Can i get sun direction for each hour via Revit API?
Hi everyone.
I want to get sun direction for each hour form Revit sunsetting but in Dynamo it can get only 1 time frame.
I didn’t found “Sun Direction” property in Revit API.
How to get it ?
Thank a lot for your recommend.
Maybe try iterating through the dates/times you need using Python and getting the altitude/azimuth angles as you do. Pretty sure they can be used to make the sun direction.
I try to follow your recommend but data from API and dynamo different.
help me please. :smiling_face_with_tear:
SunAndShadowSettings has a StartDateAndTime property which can be set.
Note that in your screenshot the times are different, likely because Dynamo didn’t reexecute.
here an example
import sys
import System
from System import DateTime
#import Revit API
clr.AddReference('RevitAPI')
clr.ImportExtensions(Revit.GeometryReferences)
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
def get_Sun_Direction(view, dateTime):
	get sun direction by date Time
	sunSettings = view.SunAndShadowSettings
	# set the DateTime
	if dateTime.Kind == System.DateTimeKind.Unspecified:
		dateTime = DateTime.SpecifyKind(dateTime, System.DateTimeKind.Local)
	sunSettings.StartDateAndTime = dateTime
	sunSettings.SunAndShadowType = SunAndShadowType.StillImage
	uidoc.RefreshActiveView()
	doc.Regenerate()
	# compute the sun direction
	initialDirection = XYZ.BasisY
	altitude = sunSettings.Altitude
	altitude = sunSettings.GetFrameAltitude(sunSettings.ActiveFrame)
	altitudeRotation = Transform.CreateRotation(XYZ.BasisX, altitude)
	altitudeDirection = altitudeRotation.OfVector(initialDirection)
	azimuth = sunSettings.Azimuth
	azimuth = sunSettings.GetFrameAzimuth(sunSettings.ActiveFrame)
	actualAzimuth = 2 * System.Math.PI - azimuth
	azimuthRotation = Transform.CreateRotation( XYZ.BasisZ, actualAzimuth)
	sunDirection = azimuthRotation.OfVector(altitudeDirection)
	return sunDirection
inputView = UnwrapElement(IN[0])
inputDateTime = UnwrapElement(IN[1])
sunDirection = get_Sun_Direction(inputView, inputDateTime)
OUT = sunDirection.ToVector().Reverse()
get_sun_direction_byTime
Thank you very much.
I have some problem when Revit model is set true north i understand in Dynamo vector refer from project base point and i don’t know how to fix this code and how to convert data is get from API to Dynamo node(value). can you explained it to me? i am beginner
:pray: :pray:
I get it just convert degree to radius right? i confuse because date in python and dynamo are difference.
Thank you very much :smile: :smile:
Hi!
I am actually using sandbox
how can I generate sun vectors on sandbox?
Try the package “Solar Analysis for Dynamo” from the dynamo team - which can be found on the package manager.
Yes I am using it but there are no solar vectors or solar position
Maybe look into the Ladybug tools libraries which have an EPW file reader in their EPW namespace:
They are informally recognized by most as the industry standard for these types of workflows in AEC.
there are interesting Python packages
a rapid test with suncalc
import sys
import System
clr.AddReference('Python.Included')
import Python.Included as pyInc
path_py3_lib = pyInc.Installer.EmbeddedPythonHome
sys.path.append(path_py3_lib + r'\Lib\site-packages')
import suncalc
from suncalc import get_position, get_times
from datetime import datetime, timezone, timedelta
def get_Sun_Direction(sun_loc):
    get sun direction by sun location
    # compute the  altitude Vector
    initialDirection = Vector.YAxis()
    altitude = sun_loc["altitude"]
    print(f"{altitude=}")
    altitudeDirection = initialDirection.Rotate(Vector.XAxis(), altitude * (180 / System.Math.PI) )
    # compute the  full Vector
    azimuth = sun_loc["azimuth"]
    print(f"{azimuth=}")
    sunDirection = altitudeDirection.Rotate(Vector.ZAxis(), azimuth * (180 / System.Math.PI)).Reverse()
    return sunDirection
inputDateTime = IN[0]
DS_Location = IN[1]
date = datetime(inputDateTime.Year, inputDateTime.Month, inputDateTime.Day, hour= inputDateTime.Hour)
print(f"date=")
lon = DS_Location.Longitude
lat = DS_Location.Latitude
sun_loc = get_position(date, lat, lon)
OUT = get_Sun_Direction(sun_loc)
