Hello everyone,
I have a Revit file which has rotated family instances, see below, and i need to get those exact rotation values to export them into Excel. Is there a way to get these values?
Thanks in advance!
Daan
Hi @Daan
Are those families structural columns? Do you need elevation rotation angle or plan rotation angle?
I need the plan rotation angle (the top down view angle)
If these are point based families which have been rotated this will return a Vector which you can get the angle from the desired axis using a Vector.AngleAboutAxis node: Dynamo Dictionary
If it is a linear element Element.GetLocation will return the location curve, which can be turned into a vector in a few ways. Angle can then be gathered as before.
Hey Jacob, these families are point families, but as seen in my second screenshot i am getting an error from using the familyinstance.facingorientation node.
I do not know why this does not work because other nodes which ask for family instance input work fine.
