Get Rotation of Instance Families in Python
Hello everyone,
I am developing a Python script in Dynamo/REVIT to obtain information about the rotation of instance families, as shown in the image below.
However, when running the code, the returned value is “NULL”. It is important to mention that this is not a selection issue, as I am indeed selecting an instance family.
Here is the code I developed:
clr.AddReference(‘RevitAPI’)
def get_rotation(family_instance):
location_point = family_instance.Location
if isinstance(location_point, LocationPoint):
return location_point.Rotation
return None
family_instances = UnwrapElement(IN[0])
rotations =
for instance in family_instances:
rotation = get_rotation(instance)
rotations.append(rotation)
OUT = rotations
Can anyone help me with the code? Where am I going wrong?
Note: I am aware that there are Dynamo packages, such as the GENIUS LOCCI tools, that solve this problem, but I do not want to use them. I want to create my own code.
Thank you all in advance for your attention.
@ADAP-Ass.Tre ,
intresting in your rotation there is the number pi that means either 0 or 360 degres (?)…
…just for better reading, your code pasted like this
clr.AddReference("RevitAPI")
        return None
rotations = []
OUT = rotations
actually i skipped the part with isInstance, i collected in the code, so unwrapping is not necessary.
clr.AddReference('RevitAPI')
clr.AddReference('System')
# 🎣 get elements
elements = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_GenericModel).WhereElementIsNotElementType().ToElements()
# 📐 get rotation
elementRotations = [i.Location.Rotation for i in elements]
OUT = elements, elementRotations
by the way GeniusLocci is a Genius, because you can copy and modify his code for any porposes…
Hello @Draxl_Andreas Draxl_Andreas,
Thank you very much for responding to my post. Your help was crucial in solving my problem. I compared your code with mine and discovered the mistakes I made, especially with the library and the “uidoc,” among other lines. Your guidance was excellent.
I corrected the issues and adapted the code for CPython3. Here is my code:
clr.AddReference(‘RevitAPIUI’)
import System
def unwrap_elements(elements):
return elements
elements = unwrap_elements(IN[0])
elementRotations =
for i in elements:
location_point = i.Location
elementRotations.append(location_point.Rotation)
elementRotations.append(None)
Once again, thank you for your help. We can successfully close this post now.
