Get the properties of the sample line
Hi Everyone!
I can’t find the node for the sample line properties
I need to get the properties of the sample line: name, station, coordinates …e.t.c
Thanks in advance…
There is no node for this. There is only a create sample line under the alignment extensions. You can make the request on the civil 3D toolkit github : Issues · paoloemilioserra/Civil3dToolkit · GitHub
In the meantime try looking at the Sample Line Class : Help
Thanks for your answer!
Hi @lebinhx3c2012,
I wrote this up for you to try. This has not be thoroughly tested, so use with caution.
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
from System.Collections.Generic import Dictionary
cdoc = CivilApplication.ActiveDocument
def get_sample_line_vertex_info(vertex):
	keys = ["Location","Side"]
	vals = []
	output = []
	# Get Point3d of vertex location
	acPoint = vertex.Location
	# Create DesignScript point
	vals.append(Point.ByCoordinates(acPoint.X, acPoint.Y, acPoint.Z))
	vals.append(vertex.Side)
	# Create dictionary
	d = {k:v for k,v in zip(keys,vals)}
	dict = Dictionary[str,object](d)
	return dict
def get_sample_line_info(sampleLines):
	global adoc
	global cdoc
	keys = ["Name","Number","Station","Group Name","Vertices"]
	output = []
	if not sampleLines:
		return
	if not isinstance(sampleLines, list):
		sampleLines = [sampleLines]
	with adoc.LockDocument():
	    with adoc.Database as db:
				for sampleLine in sampleLines:
					vals = []
					sampleLineId = sampleLine.InternalObjectId
					obj = t.GetObject(sampleLineId, OpenMode.ForRead)
					if isinstance(obj, SampleLine):
						vals.append(obj.Name)
						vals.append(obj.Number)
						vals.append(obj.Station)
						# Get parent sample line group
						groupId = obj.GroupId
						group = t.GetObject(groupId, OpenMode.ForRead)
						vals.append(group.Name)
						# Get vertices
						vertices = obj.Vertices
						verticesDict = []
						for vertex in vertices:
							if isinstance(vertex, SampleLineVertex):
								verticesDict.append(get_sample_line_vertex_info(vertex))
						vals.append(verticesDict)
						# Create dictionary
						output.append(dict)
				t.Commit()
	return output
OUT = get_sample_line_info(IN[0])
Thank you very much!
I have a problem @zachri.jensen, I cannot get information in the Vertices List.
Nice ! Thanks for sharing this !
Use a Dictionary.ValueAtKey node with a key of “Vertices”.
Great! Thank you very much!
import sys
import DSCore
clr.AddReference('AcCoreMgd')
# Import references from Dynamo
from Autodesk.DesignScript.Geometry import Point
from DSCore import *
dataEnteringNode = IN
editor = adoc.Editor
def getSideName(val):
    if val == 0:
        side = "Left"
    elif val == 1:
        side = "Right"
    elif val == 2:
        side = "Center"
    return side
	vals = []
	vals.append(getSideName(vertex.Side))
	# Create dictionary
	return d
    global adoc, t
    output = []
    if not sampleLines:
        return
        vals = []
            # Get vertices
            verticesDict = []
            # Create dictionary
            output.append(d)
    return output
            try:
                # Use flatten list
                flst = List.Flatten(IN[0])
                OUT = get_sample_line_info(flst)
            except:
                OUT = "Error"
            t.Commit()
            pass
Camber package Useful Packages - Dynamo can extract SampleLine information.
Is there a way to set the left/right offsets of a sampleline created via the Camber package?
No, not at present.
