Line/polyline from Sample Line?
Is there a way to convert or derive a line or polyline from a C3D sample line? (Ultimately, what I’m really looking for is an intersection point between a sample line and a feature line.)
see this
and see
Thanks for directing me to that Python code. Copying it exactly into a Python code block in my dynamo script and trying it with one sample line as a selection, I get this error:
File “”, line 109, in
IndexError: index out of range: 1
(Note that in the ’ File “” ’ part, there is “string” between angle brackets, and after “in”, there is “module” between angle brackets)
The code only goes to line 108, so what could this be referring to? @zachri.jensen
hi pls
attached dyn file +drawing file
Sure, here are the files. Its just a test/development file. In the dynamo script, the python code is in the red group. You can ignore all the rest of the scratch work in progress.
feature lines1.dyn (113.9 KB)
corridors4.dwg (746.7 KB)
The reason you’re getting the index out of range error is because the node is expecting two inputs, but you’ve only provided one.
Capture
Please see this post:
lll
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
from Autodesk.AutoCAD.Colors import *
from Autodesk.Civil import *
from Autodesk import *
def extract_basecurve(sampleLines):
	output=[]
	obj=[]
	if not sampleLines:
		return
	if not isinstance(sampleLines,list):
		sampleLines = [sampleLines]
	with adoc.LockDocument():
		with adoc.Database as db:
				for SampleLine in sampleLines:
					obj = SampleLine.InternalDBObject
					vertices = obj.Vertices
					sline =  Line()
					bt = t.GetObject(db.BlockTableId, OpenMode.ForRead)
					btr = t.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite)
					sline=Line(Point3d(vertices[0].Location.X,vertices[0].Location.Y,0),Point3d(vertices[2].Location.X,vertices[2].Location.Y,0))
					sline.Color = AutoCAD.Colors.Color.FromColorIndex(AutoCAD.Colors.ColorMethod.ByAci,11)
					btr.AppendEntity(sline)
					t.AddNewlyCreatedDBObject(sline, True)
					output.append(sline)
				t.Commit()
		return output
if IN[0]:
   OUT = extract_basecurve(IN[0])
     OUT = "NO DATA"
#OUT = extract_basecurve(IN[0])
@jameshitt FYI you can accomplish this with Camber as well.
