Get the index of the maximum value in lists
Hello everyone,
I’m trying to get the index of the maximum value in every list.
Thanks in advance
Hello!
Try to change the lancing to longest
It worked for me!
Hii,
Thank you for the quick reply.
unfortunately it didnt work in my case.
hello, you can try this in transitional phase but there must be a hidden reason that I do not perceive
the fastest way is to feed the Indexoff elements via a code block
edit:
This solution is faster
Cordially
christian.stan
ohhhh Thank you Christian, what a work around!!
that was awesome and smart, it worked perfectly
Maximum item returns (Double) and seed data is (Integer)
doing *1.0 makes them double
and therefore facilitates afterwards. It was from that, I think.
Yes I think so as well. that is very logical
