I am trying to get biggest value among sub-lists and produce one list
not sure why it does work as expected
Code.txt (455 Bytes)
Yes I need python as I need better understand codes
your code has a couple of issues, you set the value of Xcurrent and you’re appending a value to pairs list at each iteration .
Try this:
maxlist = []
for i in IN[0]:
max = i[0]
for k in i:
if k>max:
max = k
pass
maxlist.append(max)
OUT = maxlist
also, python has a built in max method :
Hi it is not max value form each sub-lists… we take each element among sublists and then find largest…all sublist got same lenght
aslo we have some empty cells in lists… so will be no value in some as well
the function works with nulls as well :
i’m not sure I got this part
here is example:
[ ] [2]
[3] [ ]
[ ] [5]
[7] [2]
result should be
[2]
[3]
[5]
[7]
@Michal_Dengusiak - Not sure if this is what you are looking for, but we have a node that returns the maximum item and will replicate through sublists…works with nulls as well…
Additionally, your initial list looks like it has empty values which will likely be interpreted as strings. You may want to replace those as null values.
Hope that helps.
capture.dyn (5.2 KB)
