Hi, I need to find the origin and rotations of a point cloud link (.rcp) which has been inserted origin-to-origin but has been moved and rotated. I want to know what is the x,y,z displacement and rotation between the moved .rcp origin and the revit project origin.
I know this is an old topic but I am having the same problem as him, please help.
Can Get point cloud With Scrips
clr.AddReference(“RevitAPI”)
ref = Autodesk.Revit.DB.Reference
pCloud = UnwrapElement(IN[0])
scans = pCloud.GetScans()
for s in scans:
coords = pCloud.GetScanOrigin(s)
OUT = scans, coords
Hi @chuongmep
See here ![]()
How to get rotate value pointcloud ? I did not find in your package.
Use the Vectors from the node and compare them with the associated Vectors from the Projects coordinate system. Below is an example:
