I have a family where I were using model lines to indicate insertion point. Is it possible to get an attbirutes of those model lines (name) from project environment?
@denisyukj ,
actually i am not a big fan of model lines
so i think the smartes way is just get Element.Location
KR
Andreas
Me too, it’s just an indicator from user’s side
Hi @denisyukj
1- Add the line at subcategory
2- use Brimohareb_XXX pak. to delect this line from the project by subcategory
@Draxl_Andreas
Is P2 name of model line subcategory?
@denisyukj ,
thats the name of the nested familyinstance
Thank you for sharing. Is it open source? Asking because trying to avoid a lot of packages.
Also found information from following topic.
Hi Ahmed,
This revised version takes a list of elements and a list of subcategory names and returns a list of geometries and a corresponding list of subcategory names that the geometry belongs to enable further filtering / sorting.
Hope this helps,
Thomas
[image]
# Enable Python support and load DesignScript library and Revit nodes and services
clr.AddReference('RevitAPI')
from Autodesk.DesignScript.Geometry impor…
it is not open source, also you can use this post. it has the same concept. only if you need to get “Reference_DB”, “Reference_Geometry” in addional of Line “Geometry”. you can use these Reference or add dimention for example.
Hi Ahmed,
Hope this helps,
Thomas
[image]
