Elements belongs to Subcategories
Dear All,
I have a generic family and I have a line inside it. I load this family inside my project and I need to catch this line which belong to a subcategory I know it’s name to get it’s length or coordinates of start or end points for examples.
There is any way to do this ?
Appreciate your help.
The Python script below will look through the family geometry and return the geometry that belongs to a specific subcategory. It is written for a single family instance but can be turned into one that handles a list of elements and/or subcategory names.
# Enable Python support and load DesignScript library and Revit nodes and services
clr.AddReference('RevitAPI')
# Document
# IN
elem = UnwrapElement(IN[0]) # Unwrap family instances
subcat = IN[1] # names of subcategory
# Lists
geometries = []
# Options
geomOptions = Options()
for geom in elem.get_Geometry(geomOptions):
	for g in geom.GetInstanceGeometry():
		graphics = doc.GetElement(g.GraphicsStyleId)
		if graphics != None:
			if subcat == doc.GetElement(g.GraphicsStyleId).GraphicsStyleCategory.Name:
				geometries.append(g.Convert())
OUT = geometries
Hope this helps,
Thomas
You may also want to check out this on The Building Coder:
Hello Thomas,
it works smoothly, so nice I like it but if I have many lines and each line belong to different subcategories … might you if you don’t mind update this code … unfortunately, I don’t know python :frowning:
Hi Ahmed,
This revised version takes a list of elements and a list of subcategory names and returns a list of geometries and a corresponding list of subcategory names that the geometry belongs to enable further filtering / sorting.
Hope this helps,
Thomas
# Document
# IN
elems = UnwrapElement(IN[0]) # Unwrap family instances
subcats = IN[1] # names of subcategories
# Lists
geometries = []
subcatsOut = []
# Options
for elem in elems:
	geometries.append([])
	subcatsOut.append([])
				for subcat in subcats:
						geometries[-1].append(g.Convert())
						subcatsOut[-1].append(subcat)
OUT = geometries, subcatsOut
You are amaaaazing :grin:… Thank you very much for your time and help.
Hi everyone, i was trying to use this node, but it gives me the error in the image. I copy/pasted the Python script. I’m also using Revit 2020. What could it be?
You have to input a list to iterate the code.
