Get keynotes in phase
Hi, I want to filter keynotes by phase. Not sure how to do that. My next effort is to just delete any keynotes that are in phase 1 one so my keynote legend all will look ok for phase 2. Cant seem to collect all keynote tag categories though. This not possible with dynamo?
Found a python script that will get the keynotes. Is it possible to get the element there keynoted to so I can get its phase and then filter by it to delete all keynotes in a particular phase?
The node should work, the thing is you’re calling it on the outer list L3. not in L2. The attached example doesn’t need to set the level to L2, but just to let you know where it is done.
Another way is just flatten the list before plug in into the taggedElement node:
Gotten here so far. My normal nodes arnt working for some reason
Thanks @SeanP
clr.AddReference('RevitAPI')
tags = UnwrapElement(IN[0])
taggedelements = []
for i in tags:
	tagID = doc.GetElement(i.Id)
	taggedElem = doc.GetElement(tagID.TaggedLocalElementId)
	taggedelements.Add(taggedElem)
OUT = taggedelements
Hello @vanman,
I’ve been trying to get the all keynotes on my model, but nothing seems to work (All elements of category, Get all Keynotes or All by Family Type). Would you mind sharing the Python Script you used to get all keynotes in the model?
Hi vitor, I posted the python code in my last post on this forum. Thats all I know from memory sorry
clr.AddReference('System')
element = UnwrapElement(IN[0])
fec = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_KeynoteTags).WhereElementIsNotElementType()
elements = fec.ToElements()
OUT = elements
