UPDATE 2:
I got it figured out. I was trying to get the underline value but was using find which will not return the value but whether or not the find method was successful. I’ve changed it so that I’m actually getting the value of the underline which doesn’t need the find method:
pRange = rParagraphs(10).Range
cRange = pRange.Characters
if cRange[15].Underline == 1:
test4 = "Underlined"
test4 = "Not Underlined"
test5 = cRange[15].Text
UPDATE 1:
I managed to get each character with formatting but when I try to get the underline status for each character it is always returning 9999999 even if it is ran in a paragraph with no underlines at all.
pRange = rParagraphs(12).Range
test4 = cRange[14].Find.Font.Underline
test5 = cRange[14].Text
ORINIGAL POST:
I need to know what parts of paragraphs in a word document need to be underlined. I’m not super familiar with Microsoft.Office.Interop.Word. The closest I’ve been able to come is determining if the paragraph as no text underlined(0), all text underlined(1), or some text underlined(9999999). This obviously doesn’t help me if there is underlined text in the middle of a paragraph.
Here is what I have right now. Sorry for the messy code, I’m just testing a bunch of stuff in the word module before I actually try putting anything together.
import sys
import System
clr.AddReference("Microsoft.Office.Interop.Word")
import Microsoft.Office.Interop.Word as Word
import re
wordDoc = IN[0]
missing = System.Type.Missing
word_application = Word.ApplicationClass()
word_application.visible = False
document = word_application.Documents.Open(wordDoc, missing, True)
# Place your code below this line
wdoc = document.Range()
#test = Word.Characters(0)
rText = wdoc.Text
rParagraphs = wdoc.Paragraphs
pCount = rParagraphs.Count
pContent = []
test4 = ""
######Working with lists Below
#pFormat = rParagraphs(1).Range.ListFormat.ListLevelNumber
#pFormat = rParagraphs(1).Range.ListFormat.ListString
#pFormat = rParagraphs(1).Range.ListFormat.ListType
######Getting Underline Below
# at least 1 underline = 9999999. This will be the result for letter lists.
# all underline = 1. Entire paragraph needs to be underlined.
# No underline = 0. Entire paragraphne
pFormat = rParagraphs(6).Range.Underline
######Get Paragraph text and check if it's a MANUAL letter list
#pFormat = rParagraphs(1).Range.Text
#if re.match("^.[.]\t",pFormat):
# test4 = "Letter list"
#else:
# test4 = "NOT a letter list"
######Getting paragraph text
#pContent.append(rParagraphs(1).Range.Text)
#for i in range(pCount-1):
#pContent.append(rParagraphs(i+1).Range.Text)
word_application.Quit()
word_application = None
OUT = rParagraphs, rText, pContent, pFormat, test4
Below is some stuff I’ve tried from a bunch of searches I’ve done online. Note: a lot of this code is incomplete and causes errors.
#####Find Underline in paragraph
pFormat = rParagraphs(10).Range.Select()
pFormat.Find.Font.Underline
test4 = pFormat.Range.text
#pFormat = rParagraphs(10)
#formatSearch =
#pFormat.Find.Execute("", , , , , , , , , , , , , , )
#pFormat = rParagraphs(10).Range
#pFormat.Find.Font.Underline = Word.WdUnderline.wdUnderlineSingle
#test4 = pFormat.Find.Font.Underline = Word.WdUnderline.wdUnderlineSingle
#pFormat.Find.Execute("")
