Unexpected Indent Madness
I don’t know why the “unexpected indent” error can’t give me a line to look at. It is driving me crazy whenever I run into it. I’ve tried looking thru this code 10 times and can’t spot it. I even copied it to pycharm and can’t see any errors there relating to it.
import sys
import System
clr.AddReference("Microsoft.Office.Interop.Word")
import Microsoft.Office.Interop.Word as Word
import re
from itertools import groupby
from operator import itemgetter
wordDoc = IN[0]
missing = System.Type.Missing
word_application = Word.ApplicationClass()
word_application.visible = False
document = word_application.Documents.Open(wordDoc, missing, True)
wdoc = document.Range()
#Get word doc and paragraphs from the document
rText = wdoc.Text
rParagraphs = wdoc.Paragraphs
pCount = rParagraphs.Count
startIndex = 0
#*******************Class********************************
class WordParagraph(object):
    def __init__(self, stringContent, stringLength, paraType, paraUnderlineStart, paraUnderlineLength, listLetter, listLevel, paraTab, bulletStart, bulletLength):
        self.stringContent = stringContent
        self.stringLength = stringLength
        self.paraUnderlineStart = paraUnderlineStart
        self.paraUnderlineLength = paraUnderlineLength
        self.paraType = paraType
        self.listLetter = listLetter
        self.listLevel = listLevel
        self.paraTab = paraTab
        self.bulletStart = bulletStart
        self.bulletLength = bulletLength
#List of the class instances of the paragraphs
paragraphList = []
#******************Temp Parameters************************
pContent = "" #used for stringContent
pStringLength = 0 #used for stringLength
pParaType = 0 #used for paraType
	#ForListFormat.List
	#	2 = Bullet
	#	3 = simple numericlist(can be letters)
	#	item = not a word list but still can be a manual list
pListLevel = 0 #used for nested bullet lists will be "x" if not needed
pListLetter = 0
pParaUnderline = []
pTabbedStatus = 0
frontTrim = 0
#***Test Parameters(TO BE DELETED)***
stringContentTest = []
stringLengthTest = []
paraTypeTest = []
listLevelTest = []
listLetterTest = []
paraUnderStartTest = []
paraUnderLengthTest = []
paraTabbedStatusTest = []
#********************Main for loop*******************
for iP in range(pCount - 1):
	frontTrim = 0
	pRange = rParagraphs[iP + 1].Range
	if pRange.Characters.Count > 2:
	#stringContent
		pContent = pRange.Text
		originalContent = pRange.Text
		pContent = pContent.upper()
		if re.match("^\t", pContent):
			frontTrim = 1
		elif re.match("^\t\t", pContent):
			frontTrim = 2
		elif re.match("^\t\t\t", pContent):
			frontTrim = 3
			pass
		pContent = pContent.strip()
		stringContentTest.append(originalContent)
	#paraType, listLevel, and listLetter
		pRange.ListFormat.ListType
		if pRange.ListFormat.ListType == 2:
			pParaType = "bullet"
			pListLevel = pRange.ListFormat.ListLevelNumber
			pListLetter = 0
		elif pRange.ListFormat.ListType == 3:
			pParaType = "letter"
			pListLevel = "x"
			pListLetter = pRange.ListFormat.ListString
		elif re.match("^.[.]\t", pContent):
			pListLevel = "x"
			pListLetter = pContent[0:2]
			pContent = pContent[3::]
			frontTrim = 3
		elif re.match("^- ", pContent): #dash with space
			pListLevel = 1
			pListLetter = 0
			pContent = pContent[2::]
			frontTrim += 2
		elif re.match("^-", pContent): #dash
			pListLevel = 1
			pListLetter = 0
			pContent = pContent[1::]
			frontTrim += 1
		elif re.match("^\t\t-", pContent): # this might do nothing because of the strip at stringContent above
			pListLevel = 2
			pListLetter = 0
			pParaType = "item"
			pListLevel = "x"
			pListLetter = 0
		paraTypeTest.append(pParaType)
		listLevelTest.append(pListLevel)
		listLetterTest.append(pListLetter)
	#paraUnderline
		paraUnderIndex = []
		cRange = pRange.Characters
		for i in range(cRange.Count):
			if cRange[i + 1].Underline == 1:
				paraUnderIndex.append(i)
				pass
		pParaUnderline.append(paraUnderIndex)
	#stringLength
		pStringLength = len(pContent)
		stringLengthTest.append(pStringLength) #!!!!!DELETE!!!!!!
		#Takes the above indexes and groups them and...
		groupedIndex = []
		groupedRange = []
		count = 0
		if paraUnderIndex != []:
			listLength = len(paraUnderIndex)
			forRun = 0
			for i in range(listLength):
				forRun += 1
				if forRun < listLength:
					if i == 0:
						count += 1
						groupedIndex.append(paraUnderIndex[i] - frontTrim)
						if paraUnderIndex[i] + 1 == paraUnderIndex[i + 1]:
							count += 1
							if paraUnderIndex[i] - 1 != paraUnderIndex[i - 1]:
								pass
							count += 1
							if count > pStringLength:
								groupRange.append(pStringLength)
								groupedRange.append(count)
							count = 0
						groupedRange.append(1)
						count += 1
							groupedRange.append(pStringLength)
			groupedIndex.append("x")
			groupedRange.append("x")
	#Tabbed
		if re.match("OUTLINE", [pContent][0]) or re.match("DIVISION", [pContent][0]) or re.match("SECTION", [pContent][0]) or pParaType == "letter":
			pTabbedStatus = 0
			pTabbedStatus = 1
		paraTabbedStatusTest.append(pTabbedStatus)
	#Append the pContent for testing
		stringContentTest.append(pContent)
		paraUnderStartTest.append(groupedIndex)
		paraUnderLengthTest.append(groupedRange)
	#bulletStart and bulletLength
		groupedBulletStart = []
		groupedBulletLength = []
		if pParaType == "bullet":
			groupedBulletStart.append([0])
			groupedBulletLength.append([pStringLength])
			pBulletStart = "x"
			pBulletLength = "x"
	#Create the list of paragraphs as class instances
		paragraphList.append(WordParagraph(pContent, pStringLength, pParaType, groupedIndex, groupedRange, pListLetter, pListLevel, pTabbedStatus, groupedBulletStart, groupedBulletLength))
		pass
#***************Concat Bullet list under 1000 words*******************
concatListStart = 0
delList = []
for i in range(len(paragraphList) -1):
    if paragraphList[i].paraType == "bullet": #index is a bullet
        if concatListStart != 0: #a current bullet grouping is started
            if paragraphList[concatListStart].stringLength + paragraphList[i].stringLength < 1000: # if adding current index would go over limit for characters
            # concat characters
                paragraphList[concatListStart].stringContent = paragraphList[concatListStart].stringContent + "\n" + paragraphList[i].stringContent
            # if statement for concat underline information
                if paragraphList[i].paraUnderlineLength == ["x"]: # if i has no underline then it will not have it's underline information added
                    pass
                    if paragraphList[concatListStart].paraUnderlineLength == ["x"]: # if start list is an "x", meaning it has no underlines. It will be replaced with i's information
                        paragraphList[concatListStart].paraUnderlineLength = [paragraphList[i].paraUnderlineLength[0]]
                        paragraphList[concatListStart].paraUnderlineStart = [paragraphList[i].paraUnderlineStart[0] + paragraphList[concatListStart].stringLength]
                    else: # else it has an underline already so i's information will be appended
                        paragraphList[concatListStart].paraUnderlineLength.append(paragraphList[i].paraUnderlineLength[0])
                        paragraphList[concatListStart].paraUnderlineStart.append(paragraphList[i].paraUnderlineStart[0] + paragraphList[concatListStart].stringLength)
            # add length to the start index length
                paragraphList[concatListStart].stringLength += paragraphList[i].stringLength
                delList.append(i)
            elif paragraphList[i].stringLength < 1000: #if length would be too long but new bullet is not
                concatListStart = i
            else: # i is too long to start a list group
                concatListStart = 0
        elif paragraphList[i].stringLength < 1000:  # if new index is under limit so it becomes the new start of the bullet group
            concatListStart = i
            pass
        concatListStart = 0
# Removes the paragraphs (class instances) that have been concatenated.
for i in delList:
    del paragraphList[i]
    for g in range(len(delList)):
        delList[g] = delList[g] - 1
###########################Find start index##############################
startIndex = 0
for iP in range(len(paragraphList)):
	if re.match("^OUTLINE .* SPECIFICATIONS", paragraphList[iP].stringContent):
		startIndex = iP
		break
		pass
paragraphList = paragraphList[startIndex:]
outStringContent = []
outStringLength = []
outParaType = []
outParaUnderlineStart = []
outParaUnderlineLength = []
outListLetter = []
outListLevel = []
outParaTab = []
outBulletStart = []
outBulletLength = []
for i in range(len(paragraphList)):
    outStringContent.append(paragraphList[i].stringContent)
    outStringLength.append(paragraphList[i].stringLength)
    outParaType.append(paragraphList[i].paraType)
    outParaUnderlineStart.append(paragraphList[i].paraUnderlineStart)
    outParaUnderlineLength.append(paragraphList[i].paraUnderlineLength)
    outListLetter.append(paragraphList[i].listLetter)
    outListLevel.append(paragraphList[i].listLevel)
    outParaTab.append(paragraphList[i].paraTab)
	outBulletStart.append(paragraphList[i].bulletStart)
	outBulletLength.append(paragraphList[i].bulletLength)
##################Check for underline errors####################
underLengthCheck = []
for i in range(len(outStringLength)):
	if outParaUnderlineLength[i][0] != "x":
		if outStringLength[i] < outParaUnderlineStart[i][-1] + outParaUnderlineLength[i][-1] - 1:
			underLengthCheck.append(i)
			pass
		pass
word_application.Quit()
word_application = None
OUT = outStringContent, outStringLength, outParaType, outParaUnderlineStart, outParaUnderlineLength, outListLetter, outListLevel, outParaTab, pParaUnderline, stringContentTest, underLengthCheck, outBulletStart, outBulletLength
If you’re certain there is no indentation error, it could be the mixed use of space/tab. Happened to me when i copied code from my editor to the dynamo-python editor.
It’s a long script, but I’d (inside the dynamo-python editor) dedent everything and indent it again.
To make it quick and avoid mistakes: Select one paragraph, <shift> + <tab> completely to the left, then <tab> back in place.
Look at this section for Spaces (4) vs Tab (1):
This is what it looks like in notepad:
Yeah it was tabs instead of spaces. You are both right. I should have posted this right after Kibar posted because I found it around the same time.
Thanks to both of you.
This will get much easier from Dynamo 2.8 :smiley: You can see this in Dynamo Sandbox right now, where a new feature to show whitespace characters allows you to quickly skim through; Tabs are represented as chevrons and spaces as dots.
Any loop that contains both types will raise this error - best practise is to run only with one! But if you are copying code from StackOverflow or other places on the internet you cannot guarantee what they use.
Best practise in Python 3 land is to uses spaces instead of tabs - in particular, 4x spaces in place of a single tab :slight_smile:
The image clearly shows the error of mixed indentation here :raised_back_of_hand:
This is AWESOME!
Ok. As someone that loves using tabs because I’m lazy can I PLEASE get an explanation as to why pressing 1 key 4 times is better than 1 key once to define my indentation?
Also, is there a way of switching the indentation to tabs by default instead of spaces?
with CPython3 engine if you press Tab there will be 4 spaces
This is good to know. It does mean I have to get used to pressing tab once and backspace 4 times though haha!
