Heey guys , i hope you are doing good y’all!
I have a concern , I am extracting some properties of windows and i need their IDs to link each parameter value with its corresponding element .
Yet , when i use the IfcGUID to have their IDs , i get this:
Also i am in the need of IfcGUID not the the ID that starts with “#…”
I hope someone can help , Thank youu !
Regards
@saqouanealaa
…it looks like that you run your script severial times, before you extracted familiy location point. Open/close your script, it should run well. If not follow my instraction:
you need to backwrite the IfcGUID back to the window.
1.) export Ifc write IfcGUID back
2.) extract GUID
clr.AddReference('RevitAPI')
clr.AddReference('System')
windows = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Windows).WhereElementIsNotElementType().ToElements()
GUIDs = [ i.get_Parameter(BuiltInParameter.IFC_GUID).AsValueString() for i in windows]
OUT = windows, GUIDs
