Get host and Values from dimensions, how?
Can i get values and the host(s) of a dimension?
dimension.host
Can I sum up values for examples? or can i trigger values ? f.e. if it is 2500 write Upper Text ,…
is the host exposed to the API ?
That would be intresting, to check floorplans f.e.
KR
Andreas
You can certainly get the Value from the dimensions.
However, the “Host” may be a little harder because it is actually a reference that is embedded within a host that the dim snaps too.
You may have to gather the walls and get Thier references and then compare.
Try GeniusLoci.
Perfect node, thanks for sharing!
