Get endpoint of Leader of Independent Tag
I am needing to Get all the leader end points of Tags to Pipes. The pipes being tagged are in a linked model. So Dynamo sees the pipe Tags as Independent tags. The OOTB Nodes for getting the Leader End point do not recognize Independent Tags. I have found Nodes from the Packages MEPover and GeniusLoci that will Get the Host Tag Position. I am hoping it is as easy as updating the code, but I am not familiar with how to find the command for Leader end Instead of TagHostPosition.
doc =  DocumentManager.Instance.CurrentDBDocument
if isinstance(IN[0], list):
	tags = UnwrapElement(IN[0])
	tags = [UnwrapElement(IN[0])]
listout = []
for x in tags:
	loc = x.TagHeadPosition.ToPoint()
	listout.append(loc)
OUT = listout
Long Story Short, I am trying to move all the Attached pipe tags that are to the center of the pipe, make them free end and move the leader to edge of pipe. I can get this to work when the pipes are not in a linked model and I am tagging from the same model, but when the pipes are in a linked model it will not work because the nodes get errors with Independent Tags instead of them being PipeTags.
Thanks, sorry for the long post. :slight_smile:
@jtmiller ,
i get a point :wink: BUT i cleaned up your code.
i think its not correct
import sys
clr.AddReference('RevitAPI')
clr.AddReference('System')
listout =[]
for x in tags:
    listout.append(loc)
OUT = listout
Thank you @Draxl_Andreas for the rewrite. I might have not described my problem incorrectly. I am looking to get the Leader End point instead of the TagHeadPosition. Do you think you could update that? I am not sure what to update TagHeadPosition with.
@jtmiller ,
seems not to be exposed … hmmm
Hello
a workaround by temporarily setting the LeaderEndCondition to free
get end leader
import sys
#import Revit API
app = uiapp.Application
sdkNumber = int(app.VersionNumber)
def setFreeEnd_temp(func):
	def wrapper(*args, **kwargs):
		tag = args[0]
		TransactionManager.Instance.ForceCloseTransaction()
		t = Transaction(doc, func.__name__)
		t.Start()
		tag.LeaderEndCondition = LeaderEndCondition.Free
		doc.Regenerate()
		ret = func(*args, **kwargs)
		t.RollBack()
		t.Dispose()
		return ret
	return wrapper
@setFreeEnd_temp
def get_endpoint_of_Tag(tag):
	if sdkNumber < 2022:
		return tag.LeaderEnd.ToPoint()
		ref = next(e for e in tag.GetTaggedReferences())
		return tag.GetLeaderEnd(ref).ToPoint()
tag = UnwrapElement(IN[0])
OUT = get_endpoint_of_Tag(tag)
Thank You! I will give this a try and let you know. I seem to have problems when it comes to Python stuff. Is it as simple as copy and paste into the Python Node?
it’s an example for 1 element, you just need to adapt the code for an input list
