Get Elements from Nested Linked Models (Linked Models within Linked Models)
I have a situation where I have linked models inside of linked models and am trying to access the elements within that deepest level of linked model. I can get the first level of linked elements using the SteamNodes or Archilab nodes but can’t seem to get down to the next nested level of elements.
The Get Linked RVT Documents node returns items for each link and sub-link but then when I use Elements.GetFromLinkedFile, I only get elements that are in the highest/first level of linked model.
Capture|690x230
I hope I explained this clearly. Any help would be appreciated! Thanks,
Jason
Apply the concept of crossed lacing to your models for more control
Been down this road before and the behavior is not what is expected.
Thanks for the reply. I think in this case, it might be easier to organize my files differently and avoid the issue all together.
Hello
a solution to search Elements only on nested Linked Models
#import Revit API
clr.AddReference('RevitAPI')
#Get Important vars
lstRvtlinkName = IN[0]
out = []
fecLnkInstace = FilteredElementCollector(doc).OfClass(RevitLinkInstance).ToElements()
for rvtLkinst in fecLnkInstace:
	lnkType = doc.GetElement(rvtLkinst.GetTypeId())
	if lnkType.IsNestedLink:
		if 	Element.Name.GetValue(lnkType) in lstRvtlinkName:
			linkDoc = rvtLkinst.GetLinkDocument()
			fecWallNest = FilteredElementCollector(linkDoc).OfClass(Wall).WhereElementIsNotElementType().ToElements()
			out.append([lnkType, rvtLkinst, linkDoc, fecWallNest])
OUT = out
Hi @c.poupin thank you for your great solution, it’s works like a charm but it’s still possible use it in the case of the nested links “GO_RVT1.rvt” file is set to Overlay (not Attachment) in the “RVT level 1.rvt” file? I have unespected error when I try get “GetLinkDocument()” from the nested links set Overlay. Maybe it’s a bug?
below some links, from @SeanP
and another from Revit API Forum
Thanks in advance. Have a good day Cheers
Hello @paris
when nested links are set to Overlay, their document are not loaded,
The link exists, but it will not be brought along.
from the api doc
Hi @c.poupin thank you very much for your quick and accurate answer and for your time, so if I understand correctly actually from my main project I can get only Name, linkInstance and ID of my nested link set to Overlay, and I can’t get his Document with python ?
Thank you very much for your assistance. Cheers
yes, because the model (and the associated document) is not loaded in the current doc
you can check list of loaded documents with Application.Documents
import sys
import System
#import Revit API
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
allsDocs = DocumentManager.Instance.CurrentUIApplication.Application.Documents
linkDocs = {x.Title : x for x in allsDocs if x.IsLinked}
no_linkDocs = {x.Title : x for x in allsDocs if not x.IsLinked}
OUT = no_linkDocs, linkDocs
here 2 examples (with a single open project file and a single RevitLinkType instance)
Hi @c.poupin , thank you very much for your precise and the very detailed reply, it’s very helpful. Thanks for your assistance. Have a good day. Cheers
