Get Element Id, some syntax-problems, why?
I stuck, i want just get RevitID via scripting:
elemIds = []
for id in IN[0]:
    elemIds.append(ElementId(id))
OUT = elemIds
2020-09-03_15h30_47
2020-09-03_15h50_25
need i an object Type?
KR
Andreas
Something like this?
elemIds = []
for id in IN[0]:
	elemIds.append(id.Id)
OUT = elemIds
Thank you!
So you can dotting in brakets also… Can i see it like this: …x.append(i.anyproperties)
can i query BuildInParameters?
Is my code from C# … i got it from anywhere?
I’m not the best person to comment on that since I’m also starting out with API.
But, yes, I believe you should be able to access the element property using that (as long as it exists for that type of element). Also, you need to unwrap the element to access the properties…
elementCategory = []
for elem in UnwrapElement(IN[0]):
	elementCategory.append(elem.Category.Name)
OUT = elementCategory
And no, ElementId(id) is not something C# specific, it’s a Constructor
It is not supposed to return the Element’s ID!
