Get Element id from Face
Hi everyone
This is code python get Element id from Face but not active
so somebody can help me fix it this python
clr.AddReference(‘RevitAPI’)
faces = UnwrapElement(IN[0])
elementlist = list()
for face in faces:
	try:
		ref = face.Tags.LookupTag("RevitFaceReference")
		elem = doc.GetElement(ref)
		elementlist.append(elem)
	except:
		elementlist.append(list())
OUT = elementlist
You only need to change the list() for empty list
Load the Python Standard and DesignScript Libraries
import sys
The inputs to this node will be stored as a list in the IN variables.
elementlist =
for face in faces:
ref = face.Tags.LookupTag(“RevitFaceReference”)
Assign your output to the OUT variable.
OUT = elementlist
elementlist = []
please import clr and use list with elementlist= [ ].Some thing like that:
elementlist = []
for face in faces:
	try:
	except:
		elementlist.append()
OUT = elementlist
facetest.dyn (6.5 KB)
