Get corner points of rooms
thanks for your Input.
what happens if we have a room with an odd number of corners?
The math in the script works only with even numbers.
For odd numbers you will need to make a check, for example like this:
I managed to make a script that will work in the case above
1234.dyn (138.9 KB)
but for anything more complicated you will need to find a different approach.
thanks
hi, can you please replace rooms with generic elements like Sqaure plates.
