Get ColorFill Scheme Properties returns Null
I’m having trouble with the GeniusLoci node Get ColorFill Scheme Properties. It returns null no matter what I try. I’m feeding it a valid ColorFillScheme.
GeniusLoci version 2022.9.16
Revit Version 22.1.30.34
Is it working for anyone else or is it just me?
Hi @steinah6,
You’re probably using project parameters, a use case I initially overlooked.
Please update the Genius Loci package with the latest version.
I’m using the built-in parameter Department, would that produce the error? Which ones should I try otherwise?
I’d rather try to get it working with 2022.9.16 if possible, it will take some time to deploy the new package to my firm. Thanks!
It is working fine for me.
You didn’t show any Dynamo graph so it’s not possible to help you further.
