Get cable / Conduit route (tab) commando
Hi all,
I’m trying te get a cable tray route from a element to the switchboard for example.
From the element to the nearest cable i have already working ( probably a roundabout way, didn’t used python ).
My question, is there a way to get the tab commando to get all element from one element to a other element in the system. in dynamo.
In Revit i select one cable tray for example and at the end of the cable tray i use tab to get all connected elements between those elements.
I hope it’s clear what trying to get.
Thanks in advance
Tim
You can try this:
Hi Einar, I think Tim just wanted to select the elements in the route between two selected elements. And that’s what I want to know too.
Like this:
Is it possible to do in Dynamo?
Hi Einar
when i have tried to replaced the conduits by cable trays it give me empty list , so this work only for conduits
Hi @Mariam.EmadLHT4U this post its a little bit old…guess you have better luck with create a new topic…and share all your material so far…BTW cabletray fittings dont have location curves, just location point
