How to set check box parameter of an element using python
Hi all, I am trying to set the structural parameter check/uncheck of a structural wall element.
Please let me know how to check and uncheck parameter of an element ? somehow I manage to get the parameter details but getting difficulty in setting the parameter like checkbox.
The code goes as below:
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
clr.AddReference("RevitAPI")
app = uiapp.Application
def tolist(obj1):
	if hasattr(obj1,"__iter__"): return obj1
	else: return [obj1]
ele = UnwrapElement(IN[0])
floors=FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Floors).WhereElementIsElementType().ToElements()
struct=ele.LookupParameter("Structural")
Getparam=struct.AsInteger()
setstru=Getparam.Set(0)
OUT = Getparam
you need a for loopto interate thrue your objects.
KR
Andreas
Okay Thanks I’ll try
2022-04-12_09h11_11
I have trouble with the lookup… where did you get it.
can you not use just a buildin enumeration?
i am not shure :slight_smile: … maybe some users are more into it.
Hi @shashank.baganeACM,
A couple of things in your initial code:
In your Revit image, you are previewing a wall, but your code says floors. Small detail I guess, since both have the Structural parameter, but just to be consistent :slight_smile:
In your collector, you are using the method WhereElementIsElementType() which will only give you types. It needs to be WhereElementIsNotElementType(), if you are collecting instances.
Whenever it’s possible to use BuiltInParameters, I’d recommend going with that, since it will provide you with a more stable code:
walls=FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Walls).WhereElementIsNotElementType().ToElements()
output = []
for i in walls:
	struct= i.get_Parameter(BuiltInParameter.WALL_STRUCTURAL_SIGNIFICANT)
	setstru=struct.Set(1)
	output.append(setstru)
OUT = output
One last detail: To set a Boolean to True, it’s 1 and not 0 :slight_smile:
Use the Snoop Objects tool to find the BIP:
Nice @MartinSpence …og ha en god påske :wink:
Tak Søren, og i lige måde :slight_smile:
Thanks @MartinSpence I really appreciate that. It works
