Hi everyone,
I’m trying to get the “primary analytical space” that a “energy analysis surface” is associated with in the energy model from revit. In the image below is shown more specific my approach:
My first attempt was by writing the code below. However I got the following error: <<File “<string>”, line 36, in <module> AttributeError: attribute ‘GetAnalyticalSpace’ of ‘namespace#’ object is read-only>>
Import DocumentManager and TransactionManager
Import RevitAPI
clr.AddReference(‘RevitAPI’)
Import Revit Nodes
Import from Revit DB and all its parts
Import from Revit Creation where the Create.NewDuct class is.
from Autodesk.Revit.Creation import *
Import ToProtoType, ToRevitType geometry conversion extension methods
#Defining Current document
con = Autodesk.Revit.DB.Analysis
#Imput of energy analysis surface
Surf = IN[0]
Start Transaction
#Get analytical Space info
con.GetAnalyticalSpace(Surf);
Stop Transaction
#Assign your output to the OUT variable
if errorReport == None:
OUT = output
OUT = errorReport
Afterwards I tried to rewrite my code in the following way and this time I didn’t get any error. However I got an empty list as an output. I don’t really know what the mistake could be.
Import RevitAPI
Import Revit Nodes
#Imput of energy analysis surface and list definition
Surf = UnwrapElement(IN[0])
elementlist = list()
Start Transaction
for con in Surf:
try:
ref = con.GetAnalyticalSpace(Surf)
elementlist.append(ref)
except:
elementlist.append(list())
Stop Transaction
OUT = elementlist
Thanks in advanced. I would really appreciate some help.
Kind regards,
Alejandro Mata
