Extract Analytical Surfaces from Heating and Cooling Loads analyse
Does anyone know if it is possible to extract the area of the analytical surfaces created by the Heating and Cooling Loads analyse ?
My purpose is to extract all these surfaces for each MEP space created.
I try with a Dynamo found in this forum buth this Analytical Surfaces have no link with the MEP Spaces.
Thank you.
Up.
Up…
Up…
are you trying to build the analytical model ?
then you can have access to the EnergyAnalysisSurfaces and you can extract the geometry
It’s better to start a new topic rather than dig up an old one.
[EDIT Moderation] - Translate (the official language of the forum is English)
Hello (I see that your Revit is in French:slight_smile: ),
Thank you for your reply !
I manage to select each analytical surface one by one via 3D, but my goal is to be able to extract (via a Dynamo I imagine?) all these surfaces in a .txt, .xls or other file… Possible in your opinion?
Thanks in advance.
Bonjour (je vois que votre Revit est en français :slight_smile: ),
Merci pour votre réponse !
J’arrive bien à sélectionner chaque surface analytique une par une via la 3D, mais mon but est de pouvoir extraire (via une Dynamo j’imagine ?) toutes ces surfaces dans un fichier .txt, .xls ou autre… Possible selon vous ?
Merci d’avance.
yes
