Get all Parameter Values, evaluate ? Revit 2024
hello,
how to use it correctly (Revit 2024). I want to use Element.EvaluateAllParameterValues()
clr.AddReference('RevitAPI')
clr.AddReference('System')
# Access the Revit application and document
app = DocumentManager.Instance.CurrentUIApplication
# Preparing input from Dynamo to Revit
elements = UnwrapElement(IN[0])
# Do some action in a Transaction
output = []
for element in elements:
    output.append(element.EvaluateAllParameterValues(Options("Kommentar")))
# Commit the transaction
# Return the output back to Dynamo
OUT = output
KR
Andreas
you can use it to get multiple parameter values for one element in one call
import System
from System.Collections.Generic import List, ISet, HashSet
element = UnwrapElement(IN[0])
iset = HashSet[ElementId]()
iset.Add(ElementId(BuiltInParameter.ALL_MODEL_INSTANCE_COMMENTS))
iset.Add(ElementId(BuiltInParameter.SCHEDULE_LEVEL_PARAM))
iset.Add(ElementId(BuiltInParameter.HOST_ID_PARAM))
lstEvalPValues = element.EvaluateParameterValues(iset)
test = [[ p.Definition.Name , p.AsValueString(doc)] for p in lstEvalPValues]
OUT = test
@c.poupin ,
i have still some trouble… i feed it with a single door…
is the syntex correct ?
when i want BuildIn - and SharedParameters…
import System
iset.Add(ElementId(BuiltInParameter.DOOR_WIDTH))
iset.Add(ElementId(BuiltInParameter.DOOR_HEIGHT))
iset.Add(ElementId(LookupParameter("Feuerwiderstandsklasse_"))
OUT = test
grafik
KR
Andreas
Revit 2024?
And replace
iset.Add(ElementId(LookupParameter("Feuerwiderstandsklasse_")))
with
iset.Add(LookupParameter("Feuerwiderstandsklasse_").Id)
@c.poupin
yes Revit 2024
this is “new in Revit API 2024” i test the nodes
#clr.ImportExtensions(Revit.GeometryConversion)
iset.Add(ElementId(LookupParameter("Feuerwiderstandsklasse_").Id))
OUT = test
it does not work… i am in Revit 2024
KR
Andreas
you need to import the HashSet class
from System.Collections.Generic import List, HashSet
@c.poupin ,
do you have selected a single door? chatGPT is just doing weard stuff :wink:
grafik
it does not work
Strange error :roll_eyes:
here my config
@c.poupin ,
i see i have older core! i will check
grafik
KR
Andreas
@c.poupin ,
no way … i can find it… i did the hotfix so dynamo and Revit uptodate
#iset.Add(ElementId(LookupParameter("Feuerwiderstandsklasse_").Id))
OUT = test
Your version of Revit is 2024 .0.2 ?
Maybe try to change the python engine (IronPython 2 or IronPython3 ) ?
@c.poupin ,
there is only CPython3
Need to Install IronPython via Package Manager
@c.poupin ,
is already installed
grafik
it’s really strange that you can’t change Python engine (I’ll check on my side)
try to re-install Revit 2024
@c.poupin ,
reinstall and rerun the Hotfix…
thanks
KR
Andreas
@c.poupin ,
finished
grafik
emty list works…
grafik
i cant detect the error
it is the same … it has the same problems with library import
