Node > DesignScript > API/Python... Is there a Dictonary that has these translations?
2019-05-28_16h26_04
Is there a dictonary f.e. that i can call “all elements by Category” via Design Script or Python or Dynamo direct? Reagarding learning it think it is important.
Are there examples in this way?, particulary to understand API/C# and Python codes!
KR
Andreas
Hi @Draxl_Andreas,
In python, you can do like that :
clr.AddReference('RevitAPI')
#Import Collections
import System
cat = IN[0]
bic = System.Enum.ToObject(BuiltInCategory, cat.Id)
catlist=FilteredElementCollector(doc).WhereElementIsNotElementType().OfCategory(bic).ToElements()
OUT = catlist
Bycategory
The previous answer solves your problem, but I would use a slightly different script, specifying a category in the code.
Like this.
as1 = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Floors).WhereElementIsNotElementType().ToElements(), FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Walls).WhereElementIsNotElementType().ToElements(), FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_GenericModel).WhereElementIsNotElementType().ToElements(), FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_StructuralFoundation).WhereElementIsNotElementType().ToElements(), FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_EdgeSlab).WhereElementIsNotElementType().ToElements(), FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_StructuralColumns).WhereElementIsNotElementType().ToElements(), FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_StructuralFraming).WhereElementIsNotElementType().ToElements(), FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Stairs).WhereElementIsNotElementType().ToElements()
