Get all categories used in a Document list
Is there any way to get all categories existing and used in a Document list, not only the current opened project file, whithout getting elements list first?
I don’t think you can get the used Categories without checking elements, but you can certainly get all project Categories. Take a look at this thread and see if it gets you started.
@ruben.romero You can try something like this with the GetElementCount Method
clr.AddReference('RevitAPI')
cats = doc.Settings.Categories
used_cat = []
unused_cat = []
for cat in cats:
	#if cat.CategoryType == CategoryType.Model or cat.CategoryType == CategoryType.Annotation:
	cate = Revit.Elements.Category.ById(cat.Id.IntegerValue)
	count = FilteredElementCollector(doc).OfCategoryId(cat.Id).WhereElementIsNotElementType().GetElementCount();
	if count>0:
		used_cat.append(cate)
		unused_cat.append(cate)
OUT = used_cat, unused_cat
It is fine but I am looking to do the same from a list of Revit Document files, not only the current opened Revit file
Orchid also have the node “Category.InDocument”
I am looking Category in Document"s"
Do you mean multiple documents?
yes, that is right, I can do it for one document but I want for multiple with python code
All documents have the same inbuild Category right.
no, this is what I want to know ultimately
Then you’ll have to loop your code for a list of documents.
I do not know how to do it unfortunately
@ruben.romero Try this:
toList = lambda x : x if hasattr(x, '__iter__') else [x]
inputdocs = toList(UnwrapElement(IN[0]))
documents = []
if inputdocs == [None]:
	documents.append(DocumentManager.Instance.CurrentDBDocument)
	for inputdoc in inputdocs:
		if inputdoc.GetType().ToString() == "Autodesk.Revit.DB.RevitLinkInstance": documents.append(inputdoc.GetLinkDocument())
		elif inputdoc.GetType().ToString() == "Autodesk.Revit.DB.Document": documents.append(inputdoc)
		else: documents.append(DocumentManager.Instance.CurrentDBDocument)
used_cat = []
unused_cat = []
for document in documents:
	cats = document.Settings.Categories
	doc_temp_used = []
	doc_temp_unused = []
	for cat in cats:
		count = FilteredElementCollector(document).OfCategoryId(cat.Id).WhereElementIsNotElementType().GetElementCount();
		if count>0:
			doc_temp_used.append(cate)
			doc_temp_unused.append(cate)
	used_cat.append(doc_temp_used)
	unused_cat.append(doc_temp_unused)
It does not work with me for unknown reason:
Hi @ruben.romero the great python code of @AmolShah works as expected:
Cheers
how is possible it works for you with # symbol in a command script?
@ruben.romero Any line beginning with a # indicates it’s a comment and won’t be interpreted by Python.
I choose to work with all categories (Model, Annotation, Analytical, View, etc) so I commented that line out.
But if you only want to work with Model and Annotation categories then you can uncomment it by removing the #. But by doing so you will have to indent all lines below it to make the code work.
documents = []
used_cat = []
unused_cat = []
	doc_temp_used = []
	for cat in cats:
			if count>0:
I tried both scripts the first and the second modified, I get same error:
Not sure what is the issue, maybe it is not considering some Categories? I am using Revit 2021
@ruben.romero I didn’t test it with 2021. Can you share the preview of Inputs entering IN[0].
