Geometry within a boundary & Geometry outside another geometry
Hi all
  1. we want to keep a set of given geometry within a geometrical boundary, how do we achieve that in dynamo? is there a node for that?
  2. we want to ensure a geometry is NOT within another geometry foot print, how do we achieve that in dynamo? is there a node for that?
Thx in advance
Arman
Hey,
I think you can do what you’re after, with a few nodes… Here’s an example which gets geometry from a scope box to find what’s inside it…
Here’s one to find what’s inside an Area…
Depending exactly what you mean by Keep, you could use a node to select in Revit or to make a group? If you select everything in a view, for example then filter out what’s in the geometry, you’ll be left with everything else?
Hope that’s of interest,
Mark
Thanks Mark! we’ll look into your solutions and see if they are what we are looking for.
regards, Arman
element.geometry and geometry intersect nodes might come in handy here
is there a node that will delete a geometry if a Boolean is false?
Dynamo geometry isn’t deleted - it’s created and not passed upstream. If you’re looking to delete a Revit element, Tool.Eraser, which I believe is in the steamnodes package should work.
Dear Experts,
I was trying to use this script. But could not manage to success. Can you help me please?
