Good morning.
I have a problem… please I would like your help…
I’m trying to get the intersection between the geometries… I just want to get the intersection as a result… but it doesn’t work for me… !
What am I doing wrong… thank you very much for your help
Hi, I believe this is what you need You only had to get rid of intersections, represented by an element, intersecting itself, which is the the element’s own geometry
I’m trying to do what you’re doing this hasn’t happened to your chain I tried to do the same. i made the file? If you look at it it seems like enough for me. Kesişmeler.dyn (57.3 KB)
