im trying to split one piece of geometry into multiple instances but im having an issue… it doesnt work it only splits it into two
Any ideas
Any ideas
File: GeometrySplit.dyn
Vikram,
Thanks for the post however it splits the geometry into two solids. is it possible to make it three solids ?
Tom
I’ve also been trying to do this. I thought a recursive function would do it but i’m not quite sure what i am doing wrong … Does anyone have an idea?
The arrow points at what i want to get.
That’s great! and VERY instructive. Thank you Dimitar.
Your lacing technique with @L1 for the tools input doesn’t make sense, because it would chop the list of planes and cut the original cuboid only once with each plane (in which case you’re better off with using the built in node directly). Try disabling it first:
