Split recursively
Please acknowledge that English is bad.
I’m trying to split multiple surface recursively.
First i’m trying to split one surface recursively.
But I did’nt find a difference with “Geometry.Split” and
“Spring Geometry.SplitRecursively” .
I want to know how.splitrecursively
Thank you.
The diverence is how you can use it
you are now using the same slice tool so it will split at the same place
ps there is a diverence in the list levels
check this out:
Although I was immature, I studied from the link I taught
It is now possible! I am very grateful to tell you. Thank you
Youre welcome
If a comment solved your problem, mark it as solution (and maye leave a like here and there).
OK! Thanks!
