Hi guys,
I’m trying to split a face using cross lines.
I expected the result should be like a checkerboard.
but the Node, Geometry.Split, did not work properly.
Do I have to specify the cutting order?
here is tested files:
splitfaceproblem.dyn (13.7 KB) splittest.rvt (3.0 MB)
Kulkul
April 11, 2020, 7:34am
2
Hi @Kamiel.Lee
Use Lunchbox Quad Grid by Face node:
hi ! I wrote the same code in your picture! But in (geometry.split) notice ! can you help me ! Thank you !
HI can u solve this problem? thank you ! i have the same problem!
Create two cutting Geometries (parallel to X and Y axes) and split consecutively.
splitface.dyn (30.8 KB)
