Hi All,
I’m trying to intersect a polycurve (from dwg 3D polyline) with planes but I don’t get all intersections I’m expecting. What other workflow should I use?
Depending on the geometry setup and intended accuracy, you may use nodes that find the Closest Point on the Geometry (polyline) to others (planes).
Try check the geometry working range: I notice that if you work “out of range” it doesn’t calculate properly the intersections
Thanks for the suggestion. I tried that but no improvements. I actually get less Intersections if I pick Extra large!
