Hi Dynamo Users,
I’m trying to retrieve the distance between my point and roof surface in my project.
With this node based version I’m able to to retrieve the closest point to the surface (P1) which is, I believe, perpendicular line to that surface.
I’m actually looking for P2.
A quick Question here: Should I create a line using my point as a start point along the Z axis and look for intersection point? Maybe you know some other nodes that I can use and get a fast result?
Just need someone’s advice of how to get this done better. I’m pretty sure that I’m very close. Thanks.
