GeniusLoci synchronize with central
when i try this node i always get false i do not know why ?
what i need after create central model relinquish all workset
so i started by open file in background than save as central than sync. to relinquish , close
Hello @Abdallah-Abdellateef and welcome to the forum…are you sure document background open give a autodesk.revit.db.document and not revit application document ?
i am sure the document still running in background , the input to GeniusLoci synchronize node it is autodesk.revit.db.document as attached photo.
but node always give me false result
I don’t think you’re supposed to synchronise a central model, only the local file, right?
If you’re trying to relinquish all worksets on a new central model, you save the file as a central model, close it, reopen it as a local file, set worksets to editable and then synchronise
yeah @Garbage_Collector guess you are right :wink: i dont know that open BG node, but with rhythm we will first need convert to autodesk.revit.db document for work in document save as…btw for save as central you will need your BG open file have worksharing enabled…i guees…and im agree the sync node is for localfile sync to central…havent tried myself so probably im wrong ;)) but probably as here with rhythm seems to create a centralfile and relinquish the central file
