Hi All,
I am trying to Panelize a imported surface from Rhino. I keep getting an error saying
“Warning: Panel.PanelQuad operation failed.
Error creating Surface: Points are coincident”
Please check the image. Any hints or clues would be great
You need list of Consecutive points. For that, explode the polysurface and get the start and end points of the curves and create surface again.
Thanks for the suggestion Kulkul
Exploding the Geometry does work in some cases. But whats the best way to get the start and end points of the curves and recreate the surface from curves? Could you suggest.
Getting the perimeter curves is one way but I am having a hard time re creating the surface.
Could you drop rhino file here.
Hi Kulkul,
I had totally missed your message. Here is the Rhino file. IP Roof for DYnamo.3dm (2.6 MB)
