The curve argument is not valid for rectangular wall creation. HELP!
Hi all,
I’m having some issues generating a wall which contains a curtain wall panel in it. I’m using Revit 2019.2 and Dynamo 2.0.2.
The Wall.by curve and level and the Wall.by curve and height both keep giving me the same warning for a specific bunch of curves in the project. 90% of the curves work and are identical from the others.
So far i have tried
-Rebuilding the curves in Rhino (Manually)
-Rebuilding the curves in Grasshopper (rebuilding and by end points)
-Rebuilding the curves in Dynamo ( by end points)
  • Sending across points and building the curve from them.
Nothing seem to be working!
Any help would be greatly appreciated.
Can you share the problematic curves?
Hi Jacob,
Attached are the curves in Rhino 6
Problem Curves.3dm (107.8 KB)
Solved!
So the curves are ever so slightly unaligned at the end points in the Z direction!!!
