Does anyone know if it’s possible to create a set of preset Areas in Revit using Dynamo similar to the manner in which the Lunchbox Create Room by Name and Number node works?
yes it is
just had to change NewRoom to NewArea in the code . Also, it requires an Area Plan, not a level :
#python nodes in dynamo 1.0
#proposed by Julien Benoit @jbenoit44
#http://aecuandme.wordpress.com/
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
uvs =[]
for i in IN[0]:
uvs.append(UnwrapElement(i).ToXyz())
level=UnwrapElement(IN[1])
roomlist=[]
# Start Transaction
for item in uvs:
uv=UV(item.X,item.Y)
a=doc.Create.NewArea(level,uv)
roomlist.append(a)
# End Transaction
OUT = roomlist
Many thanks - I’ll need to go and have a look at this in more detail, it’s a step beyond my Dynamo knowledge at present!!
You just need to create a python script node > right click on it > edit > delete the preset content and copy paste the code from my previous post .
You’ll also, in that case, need to press the little + to add an input to the node. Then you’ll have your “create area by point area plan” node
I hope this helps.
thanks - I’ll give that a go. However I don’t want to place the areas just create them so that they can be placed later. I need a set of areas to match my rooms - one will give me net area the other gross.
