I want to round down a number with 2 decimals place, but the Math.Floor node that I use displays an integer. So what node or code that suitable for my situation.
Thank you for your advice.
I try to use both Math.Floor and Math.Round together, but I still got an integer.
Anyway, thank you for your advice. <3
Multiply by 100, Floor, divide by 100.
Hi @natcha.jita,
You can also use python code to get 2decimal place. See screencap below:
numbers = IN[0]
numList = []
for num in numbers:
numList.append("{:.2f}".format(num))
OUT = numList
PS: the digit number is controlled by this number {:.2f} . If you don’t want to have any digit then you can change it to zero. {:.0f}
Only format for code with comment above
import sys
def tolist(obj1):
if hasattr(obj1,'__iter__') : return obj1
else : return [obj1]
OUT = ["{0:.2f}".format(float(i)) for i in tolist(IN[0])]
