Hello. I sent the solid object I created with Dynamo to Revit using ImportInstance and DirectShape. However, when sending it to Forma within Revit via a Revit add-in, it fails to generate these geometries. Thanks
This is a limitation of the Forma add-in for Revit, not Dynamo or Dynamo for Revit. Best to flag it in the Forma forum as a result.
Thanks @jacob.small. I tried sending this geometry directly to Forma with Dynamo. ‘SendGeometryToForma’. It worked!
