Form class cannot get measurestring to work
Ran into a snag with the MeasureString- seems as if the class isn’t registering the TEXT being passed to it:
WinForm-Dynamic-Height.dyn (12.4 KB)
Found this great form to pull from and developing my own forms in python. Didn’t realize Python also did classes- pouring more gas on the fire as I learn!
import sys
import math
clr.AddReference("System.Windows.Forms")
clr.AddReference("System.Drawing")
import System.Drawing
import System.Windows.Forms
from System.Drawing import *
from System.Windows.Forms import *
##https://forum.dynamobim.com/t/reporting-to-user-at-the-end-of-dynamo-player-script/37421/6
from System.Windows.Forms import Form,Label,Button,FormBorderStyle,FormStartPosition
##https://forum.dynamobim.com/t/winform-python-with-sharpdevelop/75872/2
class ShortForm(Form):
    def __init__(self, strtext):               ##Class initialize on new or call
        self.out = []                       ##Empty output field
        self.InitializeComponent(strtext)      ##Passs text to Initialize
    def InitializeComponent(self, strtext):    ##
        form = Form()
        form.Width = 300                    #Width
        form.Height = 200                   ##Height
        form.Text = "Script Result:"        ##Form Title
        form.FormBorderStyle  = FormBorderStyle.FixedDialog ##Remove the maximize box.
        form.MaximizeBox = False            ## Set the MinimizeBox to false to remove the minimize box.
        form.MinimizeBox = False            ## Set the accept button of the form to button1.
        form.StartPosition = FormStartPosition.CenterScreen
        form.AutoScroll = True
        label = System.Windows.Forms.Label()
        label.Parent = form
        label.Text = strtext
        label.Width = form.Width - 55
        ##https://stackoverflow.com/questions/388937/determine-label-size-based-upon-amount-of-text-and-font-size-in-winforms-c
        DynamicHt = System.Drawing.Graphics.MeasureString(str(strtext), label.Font, (int)(form.Width-55) )
        label.Height =  math.ceil(DynamicHt)
        label.AutoSize=False
        #label.Size = System.Drawing.Size(Form.Width - 55,0)    ##<<<<<<<<<<DEBUG
        label.Left=10
        label.Top= 10
        form.ShowDialog()
Text="".join(IN[0])
form = ShortForm(Text)          ##INITIALIZE SHORT FORM
Application.Run(form())
OUT=form.out
From the .Net doc MeasureString is not a Static Method
there are some examples here
Thanks- Saw those - and the python seems to be ignoring the overload of ,,
It only reports the font and width in the error- making me thing it isn’t seeing the text. Really odd.
The original post uses “SharpDevelop” which may? solve the issues?
here an example
MeasureString_test
import sys
import System
clr.AddReference('System.Drawing')
clr.AddReference('System.Windows.Forms')
import math
class Form20(Form):
	def __init__(self):
		self.InitializeComponent()
	def InitializeComponent(self):
		self._label1 = System.Windows.Forms.Label()
		self._buttonFill = System.Windows.Forms.Button()
		self.SuspendLayout()
		# label1
		self._label1.BorderStyle = System.Windows.Forms.BorderStyle.FixedSingle
		self._label1.Font = System.Drawing.Font("Microsoft Sans Serif", 12, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, 0)
		self._label1.Location = System.Drawing.Point(12, 25)
		self._label1.Name = "label1"
		self._label1.Size = System.Drawing.Size(368, 83)
		self._label1.TabIndex = 0
		self._label1.Text = "MyText"
		# buttonFill
		self._buttonFill.Location = System.Drawing.Point(126, 130)
		self._buttonFill.Name = "buttonFill"
		self._buttonFill.Size = System.Drawing.Size(142, 38)
		self._buttonFill.TabIndex = 1
		self._buttonFill.Text = "Rearrange Text Rectangle"
		self._buttonFill.UseVisualStyleBackColor = True
		self._buttonFill.Click += self.ButtonFillClick
		# Form20
		self.ClientSize = System.Drawing.Size(392, 180)
		self.MaximizeBox = False
		self.MinimizeBox = False
		self.FormBorderStyle = FormBorderStyle.FixedDialog
		self.Controls.Add(self._buttonFill)
		self.Controls.Add(self._label1)
		self.Name = "Form20"
		self.Text = "Form20"
		self.ResumeLayout(False)
	def ButtonFillClick(self, sender, e):
		with self.CreateGraphics() as g:
			size = g.MeasureString(self._label1.Text, self._label1.Font)
			# add margin
			size += System.Drawing.SizeF(5.0, 5.0)
			# ajust label size
			self._label1.Height = math.ceil(size.Height)
			self._label1.Width = math.ceil(size.Width)
objForm = Form20()
objForm.ShowDialog()
Ok found the means to wrap text and scroll vertically only in a fixed size dialog. This wraps the text to the form width -40px allowing the auto-wrap to be constrained to that width with unlimited height for a scroll…
I maybe wasn’t clear before. @c.poupin - I had seen the class wrapper here in the youtube python net tutorials but the spokesperson is just following the examples; yours was quite helpful with the basic class wrapper to use for comparison!
forms are sooo much easier editing graphically!
import sys
import System
from System import Drawing
import math
class popup(Form):
    def __init__(self,text):
        self.InitializeComponent(text)
    def InitializeComponent(self,text):
        #form = Form()
        self.ClientSize = System.Drawing.Size(300, 200)                 ##Height
        self.Text = "Result:"        ##Form Title
        self.FormBorderStyle  = FormBorderStyle.FixedDialog ##Remove the maximize box.
        self.MaximizeBox = False            ## Set the MinimizeBox to false to remove the minimize box.
        self.MinimizeBox = False            ## Set the accept button of the form to button1.
        self.StartPosition = FormStartPosition.CenterScreen
        self.AutoScroll = True
        self.ScrollBars = ScrollBars.Vertical
        ########Label for text#####
        self.label = Label()
        self.label.Parent = self
        self.label.Text = text
        self.label.TextAlign = ContentAlignment.TopLeft
        self.label.Font = System.Drawing.Font("Tahoma", 10, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, 0)
        self.label.AutoSize = True
        ##https://stackoverflow.com/questions/1204804/word-wrap-for-a-label-in-windows-forms
        ##This was the key to the wrapping inside the label in the form...
        self.label.MaximumSize  = System.Drawing.Size(self.Width-40,0)
        self.label.WordWrap=True
        self.label.Left=10
        self.label.Top=10
text="".join(IN[0])
oForm=popup("FOO" + text)   ##Set the form with the text value
oForm.ShowDialog()          ##Show the form
For anyone else looking to use this here is a dyn with the examples enclosed:
Legends-Delete-Unused-V01-00.dyn (16.0 KB)
